 Sujet du message: DC detector
MessagePosté: Jeu 10 Mar 2005, 23:57
Salut !
Un pic equipé d'une frequencemetre peut t'il detecter le DC ?
je par sur le principe de la tres basse frequence, le pic coupe le relais si il y a par exemple moin de 15hz...
voyé ?
bye
pour la frequence, c'est à determiner...
MessagePosté: Ven 11 Mar 2005, 00:20
1er code
http://www.melabs.com/resources/samples ... ounter.zip
Code:
    ' Pulse counter
    ' File name : Count_Display.bas
    ' Company : Mister E
    ' Programmer : Steve Monfette
    ' Date : 27/12/2004
    ' Device : PIC16F84A-20/P
    ' This program display to 3 x 7 segments dislay the result of
    ' pulses count on PORTA.4 pin/sec.
    ' Hardware connection :
    '      1. 3 X 7 segments display on PORTB<7:0>
    '      2. 3 X PNP transistor on PORTA<3:0> to drive common anode
    '         of each 7 segments display
    ' Programming mode and PIC define
   @ __config _HS_OSC & _WDT_ON & _PWRTE_ON
    ' HS oscillator
    ' Enable watch dog timer
    ' Enable power up timer
    DEFINE OSC 20 ' use 20 MHZ oscillator
    ' I/O Definition
    TRISA = %11110000 ' PORTA  : <2:0> outputs to common Anode of 7 segment
                      '                1. PORTA.0 More significant
                      '                2. PORTA.2 Less significant
                      '        : PORTA.4 input for signal
    TRISB = 0         ' PORTB connected to 7 segments
                      '       B0 : segment a
                      '       B1 : segment b
                      '       B2 : segment c
                      '       B3 : segment d
                      '       B4 : segment e
                      '       B5 : segment f
                      '       B6 : segment g
                      '       B7 : segment decimal dot
    ' Internal EEPROM definition
    data @0,192,249,164,176,153,146,130,248,128,144 ' table to convert
                                                    ' numbers to 7 segments
                                                    ' pattern output when
                                                    ' drive invert
    ' Interrupt and register definition
    OPTION_REG = %1111000   ' TMR0 clock source : RA4/T0CKI
                            ' increment on low to high transition
                            ' Prescaler assign to WDT
                            ' WDT rate 1:1
    INTCON = %10100000      ' Enable global interrupt
                            ' Disable EE write interrupt
                            ' Enable TMR0 overflow interrupt
    ' Variable definition
    DisplayPort  var PORTB   ' Port for 7 Segments
    ClockInput   var PORTA.4 ' Input pin for signal
    _7Seg1       con 14      ' enable more significant 7 segment display
    _7Seg2       con 13      ' enable mid significant 7 segment display
    _7Seg3       con 11      ' enable less significant 7 segment display
    Digit_1        var byte    ' Hundreds digit
    Digit_2        var byte    ' Tenth digit
    Digit_3        var byte    ' Unit digit
    ToBeDisplay    var word    ' Result of count to be send to 7 segment display
    Display      var byte    ' Temp variable
    DisplayLoop  var byte    '
    Delay        var word    ' Variable for Delay loop
    OverFlowVar  var word    '
    Thousands    var bit    ' Flag for count >= 1000 & < 10 000
    TenThousands var bit    ' Flag for count >= 10 000
    ' Variable and software initialisation
    tobedisplay = 0 ' set initial value of count
    TMR0 = 0        ' reset prescaller
    on interrupt goto SetVarToBeDisplay
MainLoop:
    ' MainLoop
    ' 1. display the result of the count on RA4 pin
    ' 2. refresh display
    ' 3. reset Timer0
    ' 4. reload prescaler.
    ' Duration of the procedure : 1 sec
    '           fine tuned by DelayBetweenEachDisplay Sub
    ' Looping 1 sec and get results of the pulse count in
    ' TMR0 + OverFlowVar
    DisplayRefresh:
    ' Testing amount of count
    ' Get the result of count and place decimal point flag
    ' on the according 7 segments
    If tobedisplay>=1000 then
       tobedisplay=tobedisplay/10
       if tobedisplay>=1000 then
          Thousands=0
          TenThousands=1
       else
          TenThousands=0
          thousands=1
       endif
     else
       thousands=0
       tenthousands=0
    endif
    ' convert digit to 7 segment output pattern
    display=ToBeDisplay dig 2 ' Read hundreds digit
    read display,digit_1      ' Convert hundreds
   if thousands==1 then digit_1=digit_1 & $7F ' enable decimal dot
                                              ' by clearing PORTB.7
    display=ToBeDisplay dig 1 ' Read tenths digit
    read display,digit_2      ' Convert tenths
    if tenthousands==1 then digit_2=digit_2 & $7F ' enable decimal dot                          '
    display=ToBeDisplay dig 0 ' Read units digit
    read display,digit_3      ' Convert units
    ' Send digit to 7 segments
    for displayloop = 0 to 111 ' loop for about 1 sec
        ' display hundreds
        PORTA=_7seg1        ' enable hundreds 7 segment
        displayport=digit_1 ' display
        gosub DelayBetweenEachDigit
        ' display tenth
        PORTA=_7seg2        ' enable tenth 7 segment
        displayport=digit_2 ' display
        ' display units
        PORTA=_7seg3        ' enable unit 7 segment
        displayport=digit_3 ' display
    next
    tobedisplay = OverFlowVar + TMR0
    OverFlowVar = 0 ' Reset OverFlowVar
    goto DisplayRefresh
DelayBetweenEachDigit:
    ' DelayBetweenEachDigit
    ' Produce delay of about 3 mSec
    ' Fine tuned with MPLAB StopWatch to get MainLoop = 1 sec
   for delay=1 to 307
       @ nop
   next
   @ nop
   @ nop
   @ nop
   @ nop
   @ nop
   @ nop
   @ nop
    return
    disable
SetVarToBeDisplay:
    ' SetVarToBeDisplay
    ' interrupt routine of TMR0 overflow
    ' Reset prescaller
    ' Reset overflow flag
    OverFlowVar = OverFlowVar + 256
    INTCON.2 = 0 ' clear overflow flag
    TMR0 = 0     ' reload TMR0
    resume
MessagePosté: Sam 23 Avr 2005, 22:15
pas la peine d'aller si loin !
un gros filtre passe bas en sortie
(genre resistance de 220k pour pas perturbe la sortie et un condo de 10µF)
attaquant un AOP (pour pouvoir faire une offset de 2.5V) dont la sortie attaque le PIC sur un des ADC !
MessagePosté: Dim 24 Avr 2005, 13:29
le condo ne va pas se charger tout seul sans DC ?
MessagePosté: Dim 24 Avr 2005, 17:58
y a des systemes tout fait ...pk te faire chier ??
MessagePosté: Dim 24 Avr 2005, 18:56
Un condensateur laisse passer l'alternatif, donc forcement tous va passer a la masse... (c'est cette caracteristique qu'on utilise pour les condo de liaison, le continue est bloquer et l'alternatif passe)
Ux86 : peut être qu'il veut faire comme moi, un PIC qui gere l'alumage (SoftStart, la tempo des HP), l'extinction (l'anticloque), la protection thermique...
MessagePosté: Dim 24 Avr 2005, 19:18
faudrait déjà que son aleph fonctionne correctement lol
pour la protection je disais qu'il y avait des schema éprouvé pour ca ... donc à utiliser
apres .... il peut metre un PIC pour là où il veut
MessagePosté: Dim 24 Avr 2005, 22:06
exactement ;)
tout est ok, manque le DC Protection, et la temperature mais pas vraiment besoin
MessagePosté: Dim 24 Avr 2005, 22:08
ouai mais sur un AX c different je pence !
il faut gerer le DC Offset, et 2x la detection du continu
MessagePosté: Dim 24 Avr 2005, 22:11
c'est la même chose :roll:
MessagePosté: Dim 24 Avr 2005, 22:41
oui bien sur :roll:
sans parler de la difference entre -/+ (pke pas de masse...)
MessagePosté: Dim 24 Avr 2005, 22:52
Bonsoir, voici mon très humble avis.
15Hz me parait sacrément haut pour une composante "DC".
Dans les détection DC que j'ai vu ici ou là, les schémas divergent selon le but recherché juste après l'extraction de la composante "DC" (en général par un simple filtre RC). Les protections DC cascadent en général avec une fonction seuil (ex: changement d'état d'un transistor), alors que les rattrapages d'offset appliquent une fonction linéaire à la composante DC (ex: intégrateur).
Je ne connais pas les PICs, encore moins leurs capacités de détection de fréquence. En tout cas, c'est pas très naturel pour moi bosser dans le domaine fréquentiel avec un signal large pour extraire et traiter des évênements de très très basse fréquence (<5Hz). Ex: les problèmes de latence de détection, la dérive de l'acquisition, que sais-je encore... Ca me parait plus simple et pas beaucoup plus couteux de bosser en temporel sur la composante DC extraite. De ce point de vue, j'imagine que c'est presque le même code que la gestion thermostatée d'un ventilo.
Yoghourt
Dzharis: raaaaaah lovelyyyy!
MessagePosté: Lun 25 Avr 2005, 20:47
regarde le schema interne d'un ths4131
regarde la sortie surtout :)
il faudrait ca sur une ampli
