Bonsoir Yves et Pascal
j'ai intégré la formule de ce matin dans le .inc , comme suit
Code:
* 6528 - IDH series regulator medium-mu twin Bp P K I=(m)*uramp(()*V(G,K)+V(P,K))^1.5
* From Tung-Sol 6528 datasheet - traced on 16-02-02 by AF
.subckt 6528 P G K
Cgp G P 23.8p
Ci G K 17.8p
Co P K 2.9p
* Child-Langmuir law: mean fit error 25.0242 mA
* Bp P K I=(0.3559772988m)*uramp((7.86659783)*V(G,K)+V(P,K))^1.5
* Child-Langmuir law with contact potential: mean fit error 24.8355 mA
* Bp P K I=(0.3244693488m)*uramp((7.936004301)*V(G,K)+V(P,K)+(4.406782236))^1.5
* Rydel model (4 parameters): mean fit error 20.9329 mA
* Bp P K I=((0.3525471084m)+(0.005254542469m)*V(G,K))*uramp((7.339848458)*V(G,K)+V(P,K)+(1.392894813))^1.5
* Rydel model (5 parameters): mean fit error 17.7784 mA
* Bp P K I=((0.3936510891m)+(0.005748292777m)*V(G,K))*uramp((6.847445611)*V(G,K)+V(P,K)+(-16.43556807))^1.5 * V(P,K)/(V(P,K)+(-20.10214329))
* Koren model (4 parameters): mean fit error 5.80628 mA
* Bp P K I=(0.2124272826m)*uramp(V(P,K)*ln(1.0+exp((3.813392191)+(3.813392191)*(9.930011045)*V(G,K)/V(P,K)))/(3.813392191))^(1.642411536)
* Koren model (5 parameters): mean fit error 5.37207 mA
* Bp P K I=(0.1751892114m)*uramp(V(P,K)*ln(1.0+exp((3.120020249)+(3.120020249)*(10.97189796)*V(G,K)/sqrt((2.007903552k)+V(P,K)^2)))/(3.120020249))^(1.684546085)
* Modified Koren model (6 parameters): mean fit error 3.23006 mA
* Bp P K I=(0.09784039884m)*uramp(V(P,K)*ln(1.0+(-0.04138702035)+exp((0.8666964893)+(0.8666964893)*((21.77476809)+(-85.47410585m)*V(G,K))*V(G,K)/V(P,K)))/(0.8666964893))^(1.696071534)
* Modified Koren model (8 parameters): mean fit error 2.95928 mA
Bp P K I=(0.07700487m)*uramp(V(P,K)*ln(1.0+(-0.04391691508)+exp((0.7037640055)+(0.7037640055)*((24.75373624)+(-98.12452432m)*V(G,K))*V(G,K)/sqrt((-55.26509284)**2+(V(P,K)-(16.71401283))**2)))/(0.7037640055))**(1.70779373)
* Bgg G K I=5E-6*(URAMP(V(G,K)+0.2)**1.5)
Bgg G k I=IF(V(G,K)>0, 5.10044246234457E-09 * ((( 4238.969348634 +V(P,K))/( 281.39443771702 +V(P,K)))**4)*V(G,K)**1.5,0)
.ends 6528
Le schéma de test est celui-ci
le bode est celui là
reste a me dire si ça conviens ou si faut adapter pour tendre vers plus de donnée réelle
Après validation du modèle de tube on pourra s'attaquer au TRS qui du coup tu m'arrête Yves si je me trompe
mais faut le voir comme dans un circlotron , le courant d'un tube passe dans un sens tandis que le courant
de l'autre tube passe en sens inverse , c'est bien ça
